1. Oliver
  4. Monday, 22 February 2021
I have a litte issue with the module extension j51_rotate.
I added this module to this site: https://th3-projekte.de/_schule/
As you can see at the bottom under "Unsere Partner:" the items are not side-by-side as in your demo.
In the configuration we set transistion axis to horizontal, so we expected it to run horzontal.
What do we do wrong?
Are there other classes we have to add to make it run?
Thanks in advance
Oliver
Hi Oliver
All should be ok no. The issue was a div within the article that was opened in the intro but only closed in the full article. This left an unclosed div in the intro list view which effected the rest of the page layout.
thank you for trying to help. I am sorry to say: it is still chaotic there ;)
Pls check here: https://th3-projekte.de/_schule/aktuelles
You still have adminrights for the page.
Thank you :)
Oliver
Hi Oliver
To replicate the blog as seen on the template demo, create a Catgeory Blog - Alternative menu item. In the Blog Layout tab of the menu item settings set the following....
# Leading Articles: 0
# Intro Articles: 6
Item Layout: Row - Image | Content
Hope this helps.
we set this option several times to horizontal and it did not work. Only for that reason we asked for help here.
If you changed anything else pls let us know... :)
I saw that you also fied the problem with the Template Header: see my post here https://www.joomla51.com/forum/emani-template-issue.
And we have third problem withthe blog. We want to have the same view as in the demo page.
See here: https://th3-projekte.de/_schule/aktuelles
What do we have to do to make it look likeinthe demo.... ?
Thank you very much für your help!
Thank you Oliver
I have set the Transition Axis option of your module settings to Horizontal and your items now transition horizontally as seen on the template demo.
Hi Oliver
