1. AlisonAMG
  4. Monday, 13 August 2018
I'm having an issue with horz rule only going 100 px vs 100% width.
Hoping you can help,
Alison
  1. https://pennywolk-jones.com/blog-single-column-4/112-the-change-my-life-challenge
Hi Alison
hr {
max-width: 100%;
Awesome sauce!
Thanks Ciaran
I tried to make a new question but after 4 times I'm adding it here.
Tags - I'm getting a 0 - Call to a member function get() on string rather than it displaying the posts that have that tag.
Thanks for your help,
Ali
  1. https://pennywolk-jones.com/component/tags/tag/waterstone
Hi Ali
I have been unable to replicate this issue locally. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Set up super admin for you.
PM'd login in FB (this is public right?)
Thank you Ali
The issue appears to be related to your Disqus plugins. Disabling these plugins resolved the issue. Note that the issue is also present with the default (Protostar) template which usually rules out a template related issue.
Hmmmm interesting
My HopeandHarry.com blog site also uses tags and Disqus and tags seem to work there.
https://hopeandharry.com/component/search/?searchword=Comic%20Expo%20Cameo&ordering=&searchphrase=all
Hi Ali
I noticed the same issue regarding this plugin mentioned here... https://github.com/joomla/joomla-cms/issues/19487#issuecomment-364981626
Let me upgrade this template so you can get a full stack error report. Gimme 20 min.
Wow I hadn't installed the 3.8.11 patch on that site yet. The patch killed my tags. :(
Just confirmed by restoring to 3.8.10 Disqus and tags work.
Well that's a drag.
Sounds like the latest Joomla patch does not play nice with the Disqus plugin at least.
I have updated your template to give you a full stack error report (Re-enable Joomlaworks plugins, enable Debug Mode in global config).
The bottom line to the error report is...
0 Call to a member function get() on string
/home/pennywolkjones/public_html/plugins/content/jw_disqus/jw_disqus.php:108
Have you an option to contact the plugin developer on the issue?
I only found out this was happening. I'm going to check out Brian Teeman's site and see if he will share what he did as he uses Disqus also.
Thanks for that info (I'm Git useless).
If J kills off tags I have a lot of sites that will have to move to another platform. :(
Thanks for your help. Sleep well when you land. :)
NB: BrianTeeman.net doesn't (or isn't now) using tags.
