1. talisien
  3. Sunday, 12 October 2014
Hello :)
Im having trouble with the Enlighten template.
Any formatting I apply such as h1, B, I and the like is not working.
I have checked the site with Joomla's Beez3 template and it does work using joomla template.
I have changed editors and cut and pasted from Dream waver into code and used the defult editor, checked on different browsers. Nothing changes the result. I can not get formatting to work.
Here is the link to the page Im working with.
website Glossary
I will add browser versions, Joomla versions and screenshots via images.
Any assistance will be great.
Browsers=
Beez Joomla template showing formatting working =
Enlighten template showing formatting NOT working =
Hi Talisien
Thank you for your very kind words and of course for sticking with us over all this time :)
Thank you :) This has fixed the issue. Im sorry it was someone else's plugin you had to help me with.
Once again you support is exemplary!
After working with your templates for over 7 years I would recommend you and your work to ANYONE!
I hope you have a good week
You appear to have a plugin on your site which is loading the following CSS... http://talisien.com.au/learn/plugins/content/buynow/assets/css/style.css
This CSS is overriding a lot of the template typography. Could you try disabling this plugin which appears to be called 'buynow' and see if the issue continues?
