1. web@netcommitalia.it
  4. Thursday, 16 April 2015
Hy,
if i select a different styles (not default) the icons (captivate your clients) start in new line
Instead setting default template only the last icon ( in ipad) start in new line
I fixed it, depends from settings of template width columns,myou can see on template demo server when you select a different style template from default. But there is the issue on ipad, the last photo is on new line
Once again could you please post a link to an example of this issue.
http://myhotel.netcommwork.com/
I did not post because you can see the issue in demo server too.
The same happens in Cashmere template with the last photo of gallery that start in new line
http://mybedandbreakfast.netcommwork.com/
You can try adding something like the following to the Custom CSS field of your templates parameters which will reduce the horizontal padding of your icons on smaller screen devices...
.j51_icon {
padding-left: 10px !important;
padding-right: 10px !important;
Ok, thanks.
I tryed to apply the same code to cashmere template:
.j51thumbs {
but it does not work,
can you help me?
For the ThumbsGallery module try the following....
.j51thumbs .j51Box {
margin-left: 3px !important;
margin-right: 3px !important;
