1. smithjd44
  4. Friday, 21 February 2020
I just rebuilt my business website using the Jasmine template.
I am having an issue of some page having a security issue with the SSL Certificate.
When you click to analyze the problem it says something is insecure perhaps images.
Could you check the site to see if you can have an idea of what might be causing the issue?
Thanks! James
  1. https://starlightwebdesign.com
Hi James
'Mixed content' errors will appear in the console tab of your browser tools (F12). In this case, it mentioned the extension you are using. It looks like your extension is linking to an image using http instead of https. Your best bet would be to contact the extension developer for a solution to this issue.
That fixed it!
How did you determine that was the issue and do you have any suggestions on what I should look at to fix the extension?
Thank you for your help!
Hi James
There appears to be a mixed content issue with a 'Creative Contact Form' extension? Does disabling this extension resolve the issue?
