1. sstamenkovic93
  3. Thursday, 16 November 2017
Dear All,
I'm in trouble with the Header of the Temp. Lifestyle.
I would like to us a Logo that is a Square . is there a way to get the LOGO-Bar a bit higher than it is now. Is there also a way, to higher up the responsive header hight so my full Logo will bi shown?
Thank you in advance.
Stefan
  1. http://danielabeautycenter.ch
Presuming I understand you correctly, could you try adding the following to the Custom CSS field of your templates parameters...
.container_spacer2 {
height: 400px;
#body_bg {
background-repeat: no-repeat;
background-size: contain !important;
