1. giuseppe
  3. Thursday, 07 June 2012
I bought J51 - Chimera  but installing it in the template returns me this error: JInstaller :: Install: Could not find XML setup file What should I do? regards Joseph
Hi giuseppe
Please ensure you have unzipped your download before installing. Once unzipped you will find your install file in the corresponding folder of the version of Joomla you are using.
thanks Ciarán I installed all right! But you do not install the module mod_tweets !
regards Joseph
The Twitter module did not install for you?
