I'm trying to insert a language switcher, on the top of the Renovate Template, but I don't seem to find a way to do so.
No predefined position seems to work, and I try to create a new module position, as explained in procedure, by adding the module in the header.php file, and than difine the style on the Custom CSS field of the template parameters, but I didn't manage to do it.
My goal is to put the flags on the top rigth, above de main menu itens.
Can you help me please.
Oscar
