1. bibbp
  4. Thursday, 26 September 2024
I am using multiple versions of the Novah Template with an overarching string of buttons to decide which of 5 template styles to use. This all works fine with one exception. If you go to the site at https://peterb224.sg-host.com/ (this is still under development) all the navigation between the different template styles works perfectly, except in the case when About Us -> Testimonials is selected. The 'About Us' menu disappears and the Home menu replaces it. This does not happen for any other menu item on any other menu.
Can you possibly advise where the error might be? Could it be something to do with the '/aboutusmenu' that appears which contrasts to '/primary-care' of other menus?
Many thanks
Peter
BTW I have tried deleting the menu, the menu item, the document, and switching the order of the menu items with no luck.
  1. https://peterb224.sg-host.com/aboutusmenu
Hi Peter
Assuming your menus are modules, have you checked the menu assignment for these modules (Eg. is the correct module assign to the correct menu items)?
When I click on Manage Menus, each menu has a single unique linked module. That module identifies the menu, and specifies the base Item as the home page of the section. The menu assignment on each of these modules says On all pages - ie they are all the same.
It seems to be something to do with the Testimonials menu item, or the testimonials article. The remainder of the menu items and the articles are fine.
Any ideas?
Peter
Got it - the Testimonials menu item was lacking the correct Template style. Fixed my bad.
Cheers!
