1. mortk1
  4. Thursday, 15 November 2018
I need to place links inside a module that will go in the footer1 or footer 2 position and I can't get them to work there.
Is there a fix for this?
Would you have a URL to an example of your links?
Please go to my development site that uses the London template at this link:
box5147.temp.domains/~garieri/
In the gray “Stay Connected” section at the bottom, the 3 social media links do not work and the “Privacy Policy” and “Powered by... links do not work. These module links will not work in the footer1 and footer2 positions. If I move the links to any other module position, they work fine.
Best regards,
Mort
Hi Mort
Could you check the URL provided as it appears to give us a 404 not found error (http://box5147.temp.domains/~garieri/).
Not sure why you can’t access it but the site is now live and you can also see the issue here:
https://garieri.com
The 5 links in the footer on the Home page don’t work.
Mort
Hi Mort
#footer-1, #footer-2 {
float: none !important;
That works! Many thanks.
Mort
