1. joomlagal
  3. Saturday, 29 November 2014
Hi there,
I am hoping you can help me with 3 issues I am having with this template.
The url of the website I am work on is: http://pba-canada.org
Problem 1. Everything works great until I switch to a responsive mode on a smaller screen or mobile. What happens is that the menu items has a white background and nothing appears until I hover over the white area. Then I can see the menu items. What I would like to do is make the background color #84a9bc and have the menu buttons a lighter shade of grey. I have looked at the css files and can't figure out how to modify this. Is this possible and how would I do this?
Problem 2. The second problem I am having is when I try to add bullets to my sidebars, example: http://pba-canada.org/become-a-pba (Module labelled: PBA Candidate Information) What happens is the bullets don't seem to appear at all just an odd little box thing. Where can I go to correct this?
Problem 3: I would like to use breadcrumbs on pages however this doesn't appear to work at all.
I have tried using the breadcrumb position and this position show way on the top and is all out of wack. I have also tried to move this to position top 1-a and although it does appear in a better position is still is out of wack. Example: http://pba-canada.org/become-a-pba
Is there a way to fix this issue?
Thanks so much for help.
Hi Joomlagirl
1. Have you since resolved this issue. Your menus appears to be now displaying as you wish?
2. We are unable to notice any list items in the module?
3. May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
Hi there
1. Yes, I copied some coding from another one of your other templates and placed this in the Responsive css portion. This seems to work with what I wanted to do and I was able to customize it to my liking:
.logo a {left:0px}
.logo a {top:0px}
.slicknav_btn {
margin: 5px 5px 6px;
text-decoration:none;
-webkit-border-radius: 4px;
-moz-border-radius: 4px;
border-radius: 4px;
background-color: #84a9bc;
.slicknav_menu .slicknav_nav a:hover {
background: #a5a5ad;
color: #ffffff;
.slicknav_menu .slicknav_nav ul li {
background: #84a9bc;
color: #ffffff;
2. I decided not to use bullets in my sidebar module and just replaced it with a simple special character instead.
3. As to the breadcrumb issue, I also decided not to use breadcrumbs since the majority of the site will be for registered users anyway. So at this point, I don't think I will even worry about it.
Thanks for your response. Have a wonderful day!
