1. mediafrog
  4. Friday, 14 March 2014
I have made some color changes in the template. Now I have some space in the top and bottom of the showcase. So what did I wrong?
Another question: I don't need the container with the copyright info. How can I disable this?
Grit
To remove the copyright area you can also add the following...
#container_copyright {display:none;}
Hi Grit
You appear to have your showcase image in a paragraph. To remove this paragraph padding/margin try adding the following to the Custom CSS field of your templates parameters..
.showcase p {
margin: 0 !important;
padding: 0 !important;
Hi Ciarán
sorry, I forgot this.
http://www.trans-zuerich.com
regards
grit
Hi Grit
