1. ziggy
  4. Saturday, 06 October 2012
Hello everybody,
I'm using oxygen template in Joomla! 2.5 system, and I set the Images and Links feature to use some images on my articles. It doesn't show any.
Any ideas?
You are just jenious. SOLVED.
Try adding the following to the Custom CSS field of your templates parameters..
[code type=css].img-fulltext-left {
float: left;
margin-top: 10px;
margin-bottom: 20px;
margin-right: 20px;
.img-intro-left {
float: left;
margin-top: 0px;
margin-bottom: 10px;
margin-right: 10px;
.img-fulltext-right {
float: right;
margin-top: 10px;
margin-left: 20px;
.img-intro-right {
float: right;
margin-top: 0px;
margin-left: 10px;
.img-intro-none {
float: right;
margin-top: 10px;
margin-left: 10px;
.img-fulltext-none {
float: right;
margin-top: 10px;
margin-left: 20px;
}[/code]
Thank you Ciaran, Just to let everybody know -
you suggested delete the 'com_content' folder in thr templates 'html' folder.. (../templates/j51_oxygen/com_content)
Actually it works, but still the images clears both sides of texts (don't float - see images).
Here is example of the way it should be with Joomla default template:
And here is the one in Oxygen
  3. # 3
I just did it.
Just note that to make sure my version is not the problem, Iv'e installed a fresh Joomla! installation at test.shovalife.co.il and it isn't showing any photos. In the default Joomla! template it works well.
Thank you very much, your help is appriciated.
Yuno.
  3. # 4
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further.
  3. # 5
thank you, iv'e done it and it didn't work. Any other ideas?
  3. # 6
If you have FTP access to your server, extract the latest version of the template (j51_oxygen.zip) and upload it to your server overwriting the original template folder (../templates/j51_oxygen). This way you can upgrade the template without uninstalling and losing any template settings.
  3. # 7
Hi Ciarán,
thanks for your reply.
How can I check wheter I'm using the latest version or not? I can't see any version number in my template files or in the backpanel. What is the latest version published?
and 2. If I uninstall the template and re-installing it - Is tere a way to backup the template configuration setiings?
  3. # 8
Hi Yuno
Ensure you are using the latest download of the template (http://joomla51.com/templates/j51-oxygen).
  3. # 9
