Hello! I use Ariana Template and put the ImageHover module in my web page. the position is Bottom 1a.
I used 4 images, and I set 4 columns, but the 4th image go on the next row. if i set 5 columns all 4 images are in row, but rimane a blank space on right.
also the back color on mouse over is non that I had set, but the default.
I hope you understood my problems, and can help me
thank you
