I have an issue with ImageHover module. I worked with it several times, and it's great.
But i need something in it, maybe you can help.
In the original, there is only the text when you hover on the image.
But what i need is:
A text over the picture
and when hover an second text.
And when click on the image, the whole image or a link to a page.
can you help to solve my issue?
Thanks,
Edgar
							Imagehover Module
						- Issue
- Edgar68
- Free Templates / Extensions
- Monday, 13 February 2023
				Hi Edgar
The solution would vary slightly depending on the hover effects you are using. Would you have a URL to an example of your ImageHover module?
				Thank you Edgar
.j51imagehover [class^="imghvr-"]::before,
.j51imagehover [class*=" imghvr-"]::before,
.j51imagehover [class^="imghvr-"]::after,
.j51imagehover [class*=" imghvr-"]::after,
.j51imagehover [class^="imghvr-"] figcaption,
.j51imagehover [class*=" imghvr-"] figcaption {
    background: rgba(72, 110, 142, 0.5);
}Ciaran
May be I misunderstood your request. When I now hover over your items you can now see both the image and the text which I believe was your request?
I want the first text to be visible over the photo (that location name) without having to hover over it first.
So I want to be able to see that photo with that name visible anyway, and when I hover over it, that the subtext also becomes visible.
Edgar
Edgar
				Hi Edgar
The only option easily available would be to always display all text with the following custom CSS...
[class*=" imghvr-fade"] figcaption,
[class*=" imghvr-fade"] > img,
[class^="imghvr-fade"] figcaption,
[class^="imghvr-fade"] > img {
    transform: translate(0,0);
[class^="imghvr-fade"]:hover figcaption {
    opacity: 1;
}Ciaran
it's not working, but maybe there is something wrong?
because other solutions such as these:
.j51rotate-nav svg {display:none;}
.layerslideshow-prev, .layerslideshow-next {
display: none;
do no longer work either
Edgar
display: none;
Edgar
				Hi Edgar
A possible cause for this is that you have an error in your custom CSS. You can use the following online tool to check.. https://jigsaw.w3.org/css-validator/#validate_by_input
- # 9
				Chiedo a Ciaran,
l'estensione (J51_ImageHover ) che trovo nel sito Sophia รจ la stessa che vendete al prezzo di 7 euro?
- # 10
Yes the ImageHover module with your template is the same as https://joomla51.com/joomla-extensions/imagehover-gallery-module-j4/sign-up
- # 11
