1. erikoraka
  4. Sunday, 06 October 2019
In the following url http://stavrodromion.org/home-gr, in bottom-1 module, even though I have set the module width to 100%, when I go to bigger screens that my Macbook pro screen, the module does not fill the whole screen from left to right and there is a grey rectangle appearing on the right side.
Please also test by reducing the %zoom of the screen below 100% to see..
I have set the number of columns of the module to 8, which is the number of images I use.
Can you please advise?
Thank you,
Eri
Hi Eri
By default this module will not display images bigger than their actual size. You can override this by adding the following to the Custom CSS field of your template settings...
[class*=" imghvr-"] > img, [class^="imghvr-"] > img {
width: 500px;
I'm afraid that this is not what I wanted...
I noticed that when I deactivate the following line in bold in the inspect elements window of the page (http://stavrodromion.org/home-gr) then I get the result I want:
@media only screen and (max-width: 1280px) and (min-width: 960px)
.j51imagehover130 .j51imghvr-item {
max-width: 33.333%;
I also notice than when I deactivate the line above then the following line in bold is activated:
display: inline-block;
max-width: 12.5%;
padding: 0px 0px;
box-sizing: border-box;
I believe that the solution might be a combination of the above.. Can you please advise?
Thank you,
Eri
Hi Eri
Could you please provide a screenshot demonstrating the issue you are having.
I sent the screenshots by email as they exceed 2 MB.
Thank you,
Eri
Thank you Eri
Could you try the following Custom CSS instead...
width: 2000px;
It works fine now! Thank you!
