1. Digijoom
  4. Saturday, 02 November 2019
I'm using template Artisan on this site with some images on the homepage in a slideshow.
On most screens the image is good responsive but not on a 17 inch screen. On 17 inch the image is not shown complete (see attachments). Can you explain or repair this?
Could you check the URL provided as it appears to giv us an empty page.
I had set a wrong url in the link. Now it's OK. You can try again.
Kees
Hi Kees
By default the images are set to fill the screen hence why they may appear cropped on some screen sizes. To disable this try adding the following to the Custom CSS field of your template settings...
.layerslideshow .img-fill {
height: auto;
.layerslideshow .img-fill img {
max-width: 100%;
