1. chrissi777
  3. Wednesday, 01 May 2024
I installed a brand new J5 and the verona template and ONLY the Image hover there is the same problem then in all my other Projects (J4 and J5) with image Hover. In J3 it was okay on all projects.
the BG is transp. and Text is always white - no matter what I use. Also with override it does not work.
Here is the plain installation. - the reason you see the text is because Top 1 has a light grey BG.
http://p668214.mittwaldserver.info/
what causes this problem?
Thanks Chris
Hi Chris
Thank you Chris
