Dear
I was willing to use the Pixeden icons in de menu and submenu. In your icons module you mention that the font awesome can only be used for icons in the front of a menu title. So in order to use the Pixeden icons I have adapted the header like this:
<link rel="stylesheet" href="images/pe-icon-7-stroke/css/pe-icon-7-stroke.css">
<!-- Optional - Adds useful class to manipulate icon font display -->
<link rel="stylesheet" href="images/pe-icon-7-stroke/css/helper.css">
The icons are shown in the menu top layer. But not in the submenu.
Can you please help us what needs to be done in order te use the pixeden icons in the submenu?
Thanks in advance.
Kind regards
Dirk Put
- put.dirk@icloud.com
- Thursday, 11 February 2021
Dear,
The URL is http://www.sji-basisschool.be
Then click on "Onze School" The first 2 parts of the submenu have another icon set.
The first entry from "Onze School" meaning "visie" has the same icon set as in the main menu "Onze school".
This icon is called "pe-7s-study". I am using a safari browser. Attached you can see that it show a strange square item.
Hopefully this helps.
Kind regards
Dirk Put
Kind regards
Dirk Put
Dear,
This is happening on a macbook and tested with the browser safari, opera, firefox and chrome.
But strangely enough it is showing correctly on my iphone when using safari, firefox, opera, chrome.
Now I have also noticed that when I reduce the window size on my macbook, to simulate a smaller device it is showing correctly.
So I think it is because then it is using a different css file? Am I correct in my way of thinking?
Kind regards
Dirk Put
Kind regards
Dirk Put
Dear,
Hereby included a view from my reduced window on mac.
See attached file.
Kind regards
Dirk Put
See attached file.
Kind regards
Dirk Put
Hi Dirk Put
[class^="pe-7s-"], [class*=" pe-7s-"] {
font-family: 'Pe-icon-7-stroke' !important;
Dear
Thank you for the feedback. I will try this tomorrow as I am back at work then. Kind regards
Dirk
Dirk
Dear,
Thank you very much for this update. I have tested it and it is working fine.
Kind regards
Dirk Put
Kind regards
Dirk Put
