1. lazyroby
  4. Wednesday, 16 March 2022
I have an issue with my icons modules. They only appear after giving consent to all cookies. If I deny cockies (except neccessary) all icons disappear. Cookies themselves did not change! You can setup cookie selection via "Datenschutz" (bottom) and "14. Cookieerklärung" in the text.
Can you find the reason and a solution for this issue?
Thx Robert
  1. https://tinyurl.com/2p8uhpm7
Hi and thanks! It seems not to be a problem with fontawesome. Even my visforms form does't work fine. I tested some ideas referring to my cookiebot tool. In my opinion cookiebot might be the trouble which I deactivated for the moment. I took a support ticket there. I will see what they say! Robert
Hi Robert
Your Font Awesome icons are been loaded from a CDN. It sounds like your cookie plugin is disallowing loading from an external source if cookies not accepted?
