1. erikoraka
  4. Tuesday, 22 November 2022
I have two issues:
  1. I added a button on the right top corner of the site https://www.gw-wineroutes.com/en/.
  2. There is also an icon on the left part of the button which should be showing like in photo attached but it does not.
    Can you please look into it?
  1. Also if you look in mobile view the header-2 is overlapped by the button and when I add css in the Home template (No 22) in the responsive options so as to move it left of the button it does not work. Whereas in the desktop template I have added the relevant css code it works. Can you please also help on this, too?
Thank you for your kind help in advance!
Best regards,
Eri
Hi Eri
1. This does not appear to be a Joomla51 component. Could you please detail how this icon was added? Is this a 3rd party extension?
2. To amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
@media only screen and (max-width:767px) {
.header-2 {
top: 65px;
3. To amend try also adding the following...
.hlANmy.hlANmy {
background-color: green !important;
I am unable to locate which template style is assigned to your home page. Regardless try adding the following to your custom CSS field to move the header position from its default position...
@media only screen and (max-width:1500px) {
.header-2 {
right: 120px;
Thank you for your help!
Regarding 2 it worked for the phone and tablet portrait but it does not work for tablet landscape..
Can you please advise?
Thank you again!
Eri
In the media query you can increase the screen size to your own taste. Eg.
@media only screen and (max-width:1080px) {
.header-2 {
top: 65px;
I changed the pixels to 1080 but nothing happens. Still in the landscape view of my ipad mini the search icon stays behind the the button.
See the following url I have applied the custom css..
Thanks again,
Eri
Hi Eri
Kind reminder on my request above. I have sent you the credentials to info@joomla51.com
Best regards,
Eri
