1. put.dirk@icloud.com
  3. Monday, 08 February 2021
Dear
I am testing the Icon module. And I am reading the explanation on your website about the icon module. It mentions that there should be an option choose for opacity and open in a new windows.
I don't seem to have the option opacity and I don't have the option open in a new window. So I can't write information that contains a link to a new page.
Can you please advice how we can get the open in a new window option and the opacity option?
Thank you for bringing this to our attention. It appears this feature was removed along the way. I will create an update for this module to ensure that the Open in a new window option is available over the coming days.
Dear Ciaran
Thank you so much for your quick attention. Looking forward for the update.
Kind regards
Dirk Put
Dear Ciaran,
Do you happen to have an update on this one? Has there been an update to this module? Should I re-install it?
Hopefully you can help me.
Kind regards
Dirk Put
Hi Dirk Put
Please install the attached update.
Once installed an option to open in a new window will appear under the URL field of your icon settings. Note this option will only appear if you have a URL set.
Dear I have installed this update and it is working fine.
Kind regards
Dirk Put
