1. mvanbergeijk
  4. Tuesday, 26 March 2024
How can I ensure that in my Serenity template the Icon and the header text in the modules are placed below each other and then centered in the middle of the block? As shown on the example page (unlimited styles, super responsive, etc.).
Marco
Hi Marco
Would you have a URL to an example of your icons module?
The url of my site: https://afc.devportaal.biz/
Regards,
Marco
Hi Marco
Presuming I understand you correctly, have you already found a solution to this issue (bottom-2a module position)?
Hoi Carian,
No, I did not found a solution. I have no idea why bottom 2a has the reguired position. How can I get this also for all my modules?
Thanks.
Marco
Please can you provide me an update for this issue?
Marco
Hi Marco
Have you tried copying the settings from the Icons module in the bottom-2a module position to the module you wish to have a matching layout? Note that the layout of the icon can be setting using the General Settings -> Icon/Text Layout option in your module settings.
Thanks for your response. I tried everything what is possible in the modules and switcht from module position. In the module J51_Icons the icons are displayed as I would like to see. However, in the module J51_News, J51_Carousel, J51_Numbers etc. the icons are next to the text and not above it. Please help!
CIaran
I have changed the orientation of your header title text and icon by adding the following to the Custom CSS field of your template style settings..
h2.mod_standard {
display: flex;
flex-direction: column;
margin-top: 20px;
Thanks for your support!
