I\'m using Joomala installation from aruba provider.
Is it not possible to load the data example on the 3rd step, but it is possible to make an FTP on remote folders.
Could you please help me?
I am not sure if I understand you correctly. When you upload the demo installer, you are unable to select the 3rd sample data option when installing? For a detailed explanation on setting up the template demo installer may I suggest the following URL... http://www.joomla51.com/tutorials/item/setting-up-the-demo-installer
I\'m to the 3rd step:
The final step of the Joomla installation is probably the most relevant when using the \'Demo Installer\' as this is where you import the sample data. In the installer we replaced Default English (GB) Sample Data with our template demo content so it is important to select this option before hitting \'Install\'.
As you can see in the file in attach, I\'don\'t have the option for load the sample data...
