1. giuseppe12345
  3. Wednesday, 10 June 2015
I formatted text in an article as " preformatted " because I like the effect as attached , the problem is that is not responsive , sends the head by cutting the words .
there is a solution to make it responsive or how I can get the same effect ?
link
This is the effect I like, but It is not responsive...
Could I ask you to detail what you wish these elements to do on smaller screen devices? They are responsive in the sense they resize on smaller screen devices.
yes, in the sense that I would keep the formatting as a graphic style , but I wish the words would fit to the device , so that quanso reduces the display screen , the words are not cut .
in the attached file number two , the format is correct , and the words are divided into mono correct , Annex 1 the words are cut and wrapped to the new line so wrong spell , cutting the words
Ok.. I understand now :)
TO resolve try adding the following to the Custom CSS field of your templates parameters...
pre {
word-break: normal;
wow!!! perfect I solved!! ...you solved :P
