1. Mol4
  4. Wednesday, 14 December 2022
On my clients testsite I'm using J51_icons. I want to put a line break in the Icon Description text but it doesn't accept HTML.
I know that when you make a change in the XML file of this extension, it was possible to use raw HTML.
But unfortunately this doesn't work anymore.
Is there another way to get this done?
Thanks!
Greetings, Ton
Hi Ton
What version of the Icons module have you installed?
I'm using version 2.0.20
Ton
Hi Ton
For this version we will need to create an override for your module. May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will create the oveerride for you. For our reference please paste a link to this post in your email.
Thank you Ton
Your Icon description field has been updated to accept safe HTML
Hello Ciaran, thanks!
Alle the best wishes for 2023 for you and your crew! :D
And to you... Wishing you the very best for you and yours for the year ahead :) :)
