1. muddasirpk
  3. Wednesday, 03 April 2013
If we see sample Resonate template at your site, at top left it says
'YOU ARE HERE: HOME'
What position we had to use to write our text there?
Actually, my company name is too long which I want to put there as our logo cannot be fixed on current potision.
If i move my logo using x and y position using template still it show only half page and get cutted, half of the space still get (over hide) by search box at top,
So is this possible , on most left (at top) I put some long text and it will go along with near to search box.
Hi Munir
This is a breadcrumbs module in the 'breadcrumb' module position.
Would you have a URL to an example of your truncated logo text?
Check this http://mysite.cluhost.info/
The whole name is Canada West Litigation Advance Ltd.
You can see it start hiding from ADV.
Try adding the following to the Custom CSS field of your templates parameters...
[code type=css].logo_container, h1.logo, h1.logo a {width: 600px;}[/code]
It works but the top logo picture is not responsive, how to make it responsive?
Hellow you can see the top text in blue is not responsive , see it at
The searh box and text overlaps.
How to make it responsive?
In your logos current position there is no way to accommodate both your logo and search field on smaller devices.
I had removed the searhbox, now i can i make the logo responsive.
Review site now at http://canadawestla.com/
Try the following..
You will need to load a new version of your logo suitable for mobile devices (portrait/landscape). To do so try adding the following CSS to the Custom CSS field of your templates parameters. This is a media query for a landscape mobile device...
[code type=css]@media only screen and ( max-width: 767px ) {
h1.logo a {background: url("/images/logo1.png";) !important;}
}[/code]
Where /images/logo1.png is the path to the logo to be loaded on a landscape mobile device.
Also add the following CSS for a portrait mobile devices..
[code type=css]@media only screen and (max-width: 440px) {
h1.logo a {background: url("/images/logo2.png";) !important;}
}[/code]
Where /images/logo2.png is the path to the logo to be loaded on a portrait mobile device.
