1. MySigma
  4. Thursday, 03 October 2024
Hi!
I'm using the ImageHover module for a handful of images, but in the mobile version the images are placed one below the other. Is it possible to display only one image and use navigation arrows (< back, forward >;) like in a carousel module? Otherwise you have to scroll to much because there will be added more pictures in the next steps.
Thanks and regards,
Manfred
Hi Manfred
Sorry to say, that option is currently not available with our ImageHover module. You could maybe display an alternative module with the same images (eg. J51 Rotate) on mobile devices.
Hi Manfred
Ref:https://getbootstrap.com/docs/4.0/utilities/display/
Create each module. On the module you wish to only display on mobile you can add the d-block d-sm-none classes to the modules Module Class. On the module you wish to hide on mobile add d-none d-sm-block.
thank you for your response! That sounds very good and would be an option! Is there a tutorial how to do that? I would give it a try.
Thank you,
Manfred
