I need to decrease the height of top2 for the Revolve template, but cannot figure out how to do this.
I notice that the height i have on my template is bigger than the demo, and i think it has to do with me not showing the above modules.
But it looks to big on the frontpage and i need to decrease it. Can you please help?
You can have a look at it here: http://fk-pensjon.no/index.php
- nettemor
- Thursday, 12 May 2016
Ok so i think i figured this out.
I entered the following in the custom css:
.top-2 {
height: 300px;
Please let me know if this is wrong and will result in any design-trouble for the template
.top-2 {
height: 300px;
![:)](https://www.joomla51.com/media/com_easydiscuss/images/markitup/emoticon-smile.png)
ahhhh, i was to quick. Dont seems to be working all good for the mobile solution.
Please advise how to decrease this height so that it will be fine in both desktop and mobile.
The current height of your modules is been determined by the height of your image in the left module position. One option would be to set a manual width for the containing module position (Extensions -> Templates -> [YourTemplateStyle] -> Manual Widths. By default as you have 2 modules your width will be 50% each. Reducing the width of the module position containing the image to say 35% will also reduce its height as it will scale down the entire size of the image.
Very good thank you! ![:)](https://www.joomla51.com/media/com_easydiscuss/images/markitup/emoticon-smile.png)
I notice that when viewing this site on iphone, the image on the left side is not showing. Is there anything i have to do to make this show (or not to show this module position) in the mobile version ?
Try removing the following from the 'Module Class Suffix' field in the advanced tab of your image module settings...
hidden-phone
i did so but it is still a bit odd. I have a big space between the slideshow and the module at top-2a/top-2b.
Will you please check again ?
Could you also try adding the following to the Custom CSS field of your templates parameters...
#container_slideshow {
height: auto !important;
