1. mp911
  3. Tuesday, 29 October 2013
I've made some changes on my website and I can't found solution to my problem.
Look at the following link : http://www.racers-lemag.fr/
I put a background image and i wan't to put the headband, with my Logo and the Menu to fully transparent ?
Only the headband, not all the background color...
Do you have any solution for that please?
Thank you very much for your help
Marc
Hi Marc
Presuming I understand you correctly try adding the following to the Custom CSS field of your templates parameters...
#container_header {
background: none repeat scroll 0 0 rgba(0, 0, 0, 0);
Ok, not working...
To understand correcty, see the following image. I wan't transparent on the black part I've showed
Hi Marc
Could you try changing the suggested CSS to the following..
#container_header {
background: none !important;
Perfect !
Thank you very much :)
In the same time, is it possible to change the background color only for a template position ?
For example in my home Page, I wan't to put the SlideShow Module in Showcase position with a transparent background (like in the following image).
But only for this module in this page... For the rest, white background is good.
Could you bring me a CSS code to change it please ?
Best Regards
Marc
Hi Marc
This should do the trick for you.. also to be added to your Custom CSS field....
#container_slideshow .wrapper960, #container_slideshow_modules .wrapper960, #container_spacer1 .wrapper960 {
background: none repeat scroll 0 0 rgba(0, 0, 0, 0) !important;
Really great !
A little bit to hard for me to understand, but the result is perfect !!!
Marc
