1. Ale
  4. Thursday, 19 November 2015
How to change color in the footer menu in Enlighten template?
See my web: http://www.kiel.cl
Regards,
There appears to be an issue with your site loading. Regardless, presuming you are referring to the templates in built footer menu, try adding the following to the Custom CSS field of your templates parameters (edit to taste)..
#footermenu ul li a {
color: #000000;
Thank Ciara,
It work...
Regards,
