Hello Ciàran,
in this you describe a method to integrate font-awesome to an older template.
My question: is the hash value for stylesheet integrity depending on the template?
If yes, can you send me the correct link for Pianoforte template?
I tried to use the link above but the result is not correct, pls be so kind and see here :
http://test.wsv-vagen.de/index.php/aktuelles-vom-verein.html
The first text on the right side includes a link "[color=#0044ff]unter Termine[/color]" with the class fa-link. But that icon is a bit strange
Thanks in advance for your help.
Oliver
