1. pidjy
  3. Friday, 20 June 2014
Hello.
I have purchased the "Smexy" Grafik template and I was wondering if you can provide any hint or method on how to achieve the "easy to customise" "Responsive layout" modules with the Icons and Text... This looks terrific.
I know how to adress a position to a HTML module... I know some custon CSS .. but I just can't figure how the J51 icons module work... All the results I get are messy regarding what you have done.. please share your knolwedge! ;)
best.
-P-
HI P
Would you have a URL to an example of your icons so we can see what may going wrong for you?
I am also struggling with the j51_icons module. I first installed Grafik on a test site, with the sample data. I re-configured “Homepage Icons” and like the module.
When I installed Grafik on the production site, I didn't want all the sample data. I tried downloading mod_j51icons from test site, then uploading it to modules directory on production site. I also following instructions for loading FontAwesome to the production site template (from elsewhere on this forum)
I can't see how to create a new J51-icons module.
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will create an example icons module for you. For our reference please paste a link to this post in your email.
Ciarán pointed out to me that the template package includes mod_j51icons.zip with the Install Files package.
