1. pearlyjones
  3. Wednesday, 19 February 2014
I've using commercial template Calibra and have placed the standard Joomla site
search module in module position base-2f in the hope that it would be to the far right of my page.
The icons module I have placed above it in base-1f is to the far right, exactly where I want it, but the search module is previewing as towards the centre of the site at the bottom and I need to move it further right.
Is there a way of doing this, please?
I am working on a temp version of my client's site/domain at present so am not publishing to the live main domain as yet, so can't give a live URL to show.
Thanks Ciarán, I was just about to send over the email to give you access and I thought I'd have one more look at it using the advice you gave before before I bothered you with it. I realised I had enabled the wrong module position width option! It now works fine. Thanks again for the great support and templates.
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will take a look fop you. For our reference please paste a link to this post in your email.
Thanks Ciaran, when I looked at the manual settings earlier they were all set at 16.6 for each base module position and I wasn't sure what to change them to. I tried to change base 2f to 30% and decrease the others accordingly but nothing happened. Am not sure what I'm doing! Please can you explain a little more how they work - I'm new to Joomla. Do I change the positions I'm not using to "0" to increase the width of the other ones? Please would you mind explaining to a novice?
May I suggest enabling the 'Manual Widths' option in the 'Manual Widths' tab of your templates parameters. This will allow you to set your own manual width rather than the default 50/50 widths which is the case in your screenshot.
