1. dinkster07
  3. Wednesday, 22 January 2020
How can I make it so the logo and the slogan for J51 Madison can each be on multiple lines? Maybe limit their width and enable word wrapping in their css settings? Right now they look like:
“This is the very long name of my website”
and
“This is the very long address of our church”
But I’d like them to look like:
name of my website”
and
of our church”
Would you have a URL to an example of your logo/slogan?
I'd also like the text on both lines to be centered. I wouldn't want it to look like
-------------------------------------"This is the very long
name of my website"
Your website appears to be currently offline. May I suggest sending temporary access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
We’ve actually got a new name. It’s livinggraceevangelical.church . I would like to try it out to leave Living Grace in the large text on the first line, then Evangelical Church in smaller text on the second line, then our address being the smallest text in the third and fourth lines. I’ll send you credentials.
Edit to taste
#logo {
max-width: 690px;
margin: auto;
I don’t know what you did, but now I can’t see any options in the backend under the template for my website. All I see is the template name. I used to be able to see all of the adjustable configuration options for the template. Now I see nothing.
No changes were made to your template/site. Have you installed any plugins since the last time you were able to access your template settings?
I have been using the user profile plugin, but I duplicated it, calling the plugin file profile10, so I could have custom changes to it without future Joomla core updates affecting the plugin. So, I actually have the user-profile10 plugin enabled (plugin file is called profile10). I know the original plugin file is called profile. Is this something used in the j51_madison scripts, to where I should add the number 10 to the end of each occurrence of profile? If this is the case, can you tell me where I would have to do that? That's all I can think of. Thanks.
I figured out which plugin is causing the issue. I have the JCE Editor installed and I recently updated it. The System-JCE plugin makes all the template configuration tabs disappear in the backend. I don’t know what the plugin is used for, but if I disable it, the template configuration tabs reappear for j51 Madison. Hmm.
Thank you for the update. It looks like this issue is related to the following post... https://www.joomla51.com/forum/caitlin-renita-buttons-tabs-for-the-parameters-disapeared-after-the-lastest-joomla-update-3-9-15
As mentioned, JCE have resolved this issue in the next update of the JCE editor.
