1. Louw
  4. Friday, 22 May 2015
Is it possible to use the same hover effect that you have in the BOUTIQUE menu in the Central Top Menu. (hvr-underline-from-left)
If it isn't would you be able to tell me if i can change the hover and active color of the Central Top menu text or background?
Thank you kindly
Hi Louw
Sorry to say this option is not available with our Central template.
To edit the hover state of your menu items try adding the following to the Custom CSS field of your templates parameters (edit to taste)...
.hornavmenu-top .hornav > ul > li:hover > a {color:#999999;}
Thanks Ciarán. Worked perfectly. Have a great day.
