1. AvalonSailingClub
  3. Friday, 17 July 2015
I would like to reduce the vercial spacing between the hornav dropdown menu items, but can't find the right area of css to do it.
I would like to reduce the gap between the text by around 50% to make a denser menu that does not use as much vertical real estate
Temp Example URL:
http://www.avalonsailingclub.com.au/j/index.php/links/template-test-home-page
Example of what I am trying to change attached
Can you please help with the appropriate css modification?
Thanks,
Steve
Hi Steve
To edit try adding the following to the Custom CSS field of your templates parameters where 4px is your vertical padding for each sub menu item (edit to taste - default 10px)...
#hornav ul ul li a {
padding: 4px 12px;
Thanks Ciaran - that was perfect.
Really appreciate you parience helping us work through these stying changes - we went live with the template today!
Thanks for the help,
Steve
