1. fratellipandolfi
  3. Friday, 18 May 2012
I use j51_oxigen free templates. In some articles i use Sliptabs with Qlue Accordion and the sub menu does not work.
Here you can try to select the sub menu Produzione/colori/colori da esterno
http://www.pandolfi.joomlahost.it/2012-04-30-10-50-12/finestre.html
Hi fratellipandolfi
There appears to be a clash between the sliptab you are using and the moomenu script of the template. If you wish you can send temporary administration access to your Joomla installation to [email protected] and we will investigate the issue further.
