1. markuskoerle
  3. Tuesday, 19 June 2018
Hi there,
I'm using tempate "Magnolia", the horizontal ruler doesn't work. It creates two little lines instead of a ruler (see attached screenshot).
Any suggestions?
Thanks!
Markus
  1. https://akademie.akgsoftware.de/index.php/gruppenschulung/vestra-infravision-akgcad/50-intensivtraining-querprofil-4
Hi Claran,
thanks for your quick response! Work fine now with your help. :D
Markus
Hi Markus
Presuming you want a single full with line as a HR, try adding the following to the Custom CSS field of your template settings..
hr {
height: 0;
max-width: 100%;
