I've just purchased the Horizon template and in the process of setting of my layout.
I am looking at the module positions from here - http://demo.joomla51.com/0080/index.php/module-positions
I wanted to show a footer section which is the same as the module shown in the demo page where it says "Who are we?" and "Payment options" (see screen shot) this module only seems to show on the module position page from what I can see but I cant figure out what module it is in the template. Any ideas?
Also from what I can see positions 25 - 30 are missing in joomla from what I can see, or am I missing something?
TIA
- cpmilez51
- Thursday, 09 August 2012
Accepted Answer
Pending Moderation
Typical just after posting that I tried a couple of positions which aren't shown in the module positions page. Base1 position was the one I was looking for. I think the module position page doesn't match with the positions on Joomla and needs to be updated/corrected.
Hi cpmilez51
Thank you for bringing this to our attention and our apologies for the inconvenience. There was indeed a difference in the module positions of the template and the positions diagram. An updated diagram of the positions of the template is now available at http://demo.joomla51.com/0080/index.php/module-positions
Accepted Answer
Pending Moderation
Hi Ciarán
Thanks for update, i've checked the updated module positions and from what I can tell it looks the same as it was, can you check it please its missing positions like base1 - base6 and user25 - user30 are not in the template.
Chris
Chris
Hi Chris
You could be still loading the old module positions image from cache. Try a full refresh on your browser (CTRL + F5).
Accepted Answer
Pending Moderation
Seems ok now thanks.
Got another issue with dropdowns not working, I noticed a js error in the chrome console which looks like could be the culprit. Any ideas? Or should I post a separate topic?
Uncaught TypeError: Cannot call method 'getElements' of null dropdown.js:87
Ensure you have added moomenu to the Menua Tag ID field of your menu modules parameters.
Accepted Answer
Pending Moderation
Thats fixed the js error thanks. Almost there now i think just one more
I have added two menu items with a parent of "Services" menu item. These sub menu items dont appear under services unless i go to the services page, any ideas?
Thanks again.
Chris
Thanks again.
Chris
In your menu modules parameters (Extensions -> Module Manager -> [MenuModule]), ensure you have set the 'Always show sub menu items' to Yes. This way your menu will diplay the sub menu on all pages and not just the page where the menu item is active.
