1. keith@parriss.co.uk
  3. Friday, 05 August 2022
Hello. I'm using Layla & want to hide items in header-3 module. I've set this to hide in responsive options on the template general page, but they are still visible. If I set showcase to hide, this does work. Could you suggest what I've done wrong please?
That's done the trick, many thanks.
On which Joomla version are you having this issue? Would you have a URL to an example of your header-3 module where the issue is present?
Hello. I've recenty downloaded the Joomla 4 version of the template, this is the development address;
https://gtts-four.cloudaccess.host/
Viewig on an Apple 12 mini, I still see the content for this module, which I would like to hide.
Hi Keith
To amend try adding the following to the Responsive Custom CSS fields within the General -> Responsive Options tab of your template settings. For more details on using these fields may I suggest the following article... https://joomla51.com/tutorials/template-parameters/applying-custom-css-to-a-screensize-device
.header-3 {
display: none;
