how can I hide a module position, which is not mentioned in the responsive section of the template, in the responsive modus?
I created a newmodule position in the template, but this should not been seen in the responsive mode.
Thanks in advance
Jürgen
- webknecht
- Tuesday, 05 April 2022
it is all so easy!!
I found the settings in the template module width section.
Jürgen
it is all so easy!!
Jürgen
I found the solution here in this forum but another problem occured-
In the mobile version the responsive menue button disappeard
Jürgen
Jürgen
in some of the 3er Templates I was able to create a newmodule position as mentioned in your tutorial.
It was easy to change the index.php of the template folder.
Where can I made the modifications in the 4er Templates???
Jürgen
Jürgen
Hi Jürgen
Presuming I understand you correctly, the file structure is the same in both the Joomla 3 and Joomla 4 versions of the template so the same change can be made within the templates index.php.
for example I used the Layla Template for Joomla 4 but in den index.php of the template folder I cannot find the <?php require("php/layouts/header.php"
So I tried:
<div id="newmodule">
<jdoc:include type="modules" name="newmodule" />
</div>
<?php require("inc/layouts/logo.php"
And really it works!!!
But another problem:
With the same installation the layerslideshow at the modul position showcase-1a will show in a width of 100% instead of the width choosed in the template layout for example 1280 px.
In other installations with this template all works fine. Can I change this also in the custom.css??
Thanks in advance
Jürgen
So I tried:
</div>
Thanks in advance
Jürgen
Now there is a small problem concerning the layer_slideshow for Joomla 4. How can I change the effect in the layer_slideshow for Joomla 4 as before in the version for Joomla 3 regarding the texts in the slider as in the attached screenshot (screenshot)
Thanks Jürgen
Thanks Jürgen
- # 10
Hi Jürgen
To amend the style of your slideshow as per the screenshot, try adding the following to the Custom CSS field of your template settings (edit to taste)...
.layerslideshow154 .info-wrapper {
background: rgba(255,255,255,.7);
.layerslideshow154 .layerslideshow-title {
background: #33b77e;
line-height: 1rem;
padding: 10px;
color: black;
text-transform: uppercase;
font-weight: normal;
font-size: 1.3rem;
.layerslideshow154 .layerslideshow-caption {
color: black;
}Ciaran
- # 11
