MENU
  1. colleen
  3. Friday, 14 December 2012
Hi -
I have tried my best to find which coding to change for the following questions but I’m stuck and thought I’d ask...
1. What is the css coding to add a space underneath all the menu titles on the left side? (I highlighted a line in yellow Life’s a journey as an example)
2. What is the code to add space above the article title? (I highlighted with a yellow line above Florida as an example)
3. How do I get rid of the category name and subcategory name in the breadcrumb? (I highlighted in red) I have changed the admin in Article Manager Options to hide the category title, description image and subcategories but they still show up. (have also chosen these options in the articles themselves, but that didn’t work either) I don’t want these to be displayed, as clicking on them shows all the articles that I have saved in that subcategory.
I’m using Joomla 2.5.8
Thanks! (Am loving your template -thanks for making it available)
Thanks for the answers! In #1, I changed the #sidecol to .sidecol and it worked perfectly and for #2, I added padding to the top. So happy to have the changes done!
I hadn't thought to post my breadcrumb problem on Joomla, but I will now...
Colleen
Hi Colleen
1. Try adding the following to the Custom CSS field of your templates parameters..
[code type=css]#sidecol_block .module_header {padding-bottom:10px;}[/code]
where 10px is your added padding.
2. Try also adding the following to the Custom CSS field of your templates parameters..
[code type=css].content_header {padding-bottom:10px;}[/code]
3. You may have to post this query to the joomla.org forums as it would not really be a template query.
