1. bludove
  4. Wednesday, 29 May 2019
I would like to display my social media icons inline with the menu on desktop and then under the logo on mobile. I cannot seem to make this happen.
Additionally, I would like to repeat the social icons in the footer but I would like to make them white in that area. Is there an easy way to do this? for now I made a module and copied in the code created for the social icons but that's not quite what I had in mind b/c it means a couple places to edit the links if they change.
Note: I have only applied the design to a hidden menu item not the whole site. I didn't want the changes to be seen until I was finished.
Lisa
  1. https://wardscottfiles.com/new-template-design
Hi Lisa
One option is to use the J51_InlineIcons module included with your template.
Thank you. That worked.
Hi Lisa
#logo {
margin-bottom: -90px;
#socialmedia {
margin-left: auto;
Also remove the following...
.hornav {
position: absolute;
top: 25px;
left: 415px;
