IHi, I´m trying configure my j51gridgallery, but I got some problem:
I want to link the pictures of gridgallery with a simple article, but in the options I only can link with menus.
I would suggest creating a menu specifically for your GridGallery module (Menus -> Menu manager -> Add new menu). Within this menu you can create a menu item for each article you wish to link to (Menus -> [YourNewMenu] -> New -> Single Article). You can then select these menu items from within your GridGallerys parameters.
Hence why you would create a new menu specifically for your GridGallery as suggested.
If you wish you can send temporary administration access to your Joomla installation to info@joomla51.com and we will link your GridGallery items to the articles of your choice for you using the suggested method above. For our reference please paste a link to this post in your email.
