Hi Ciarán.
I'm looking for the code of advertising, in server, but I can not find which file is?
Apparently somewhere in template, but, where?
I want to make some changes and I can't find...
Can you help?
Thank you!
Hi Vag
Not sure if I understand you correctly. Would you have a URL to an example of the 'advertising' in question?
Hi Vag
Sorry but I'm still at little confused by your request :unsure: . You appear to have sent me a URL to your Joomla administration. The template does not have any advertising within its code.
Hi Ciarán
I mean the ads that I have make myself.
the server that will find?
logically transferred to a file.
Thank you.
Thank you.
Do not bother other
Sorry for the inconvenience.
I'll try it myself
Thank you very much!
I'll try it myself
Hi Ciarán
Long time no talk. I hope you are well!
I want to ask... I have since then template LifeStyle
I want to make a eshop. I do the same? or need another template?
and what do you suggest?
Thank you.
vag
Thank you.
vag
Hi Vag
There is a number of eshop extensions available for Joomla, all of which should work without any issues with your Lifestyle template. Following are a list of some of the more popular eshop Joomla solutions...
http://extensions.joomla.org/extension/hikashop
http://virtuemart.net/
http://miwisoft.com/joomla-extensions/mijoshop-joomla-shopping-cart
http://extensions.joomla.org/extension/e-commerce/shopping-cart/eshop
- # 9
