1. Gislon
  3. Thursday, 09 February 2023
Hi. I'm running J51 Madison template. I haven't had to update it for a few years and I've forgotton where I find the banner text to update it. Very grateful if anyone knows where it is. This is the site: https://trudiday.co.uk/
I just want to change the banner text that currently says: "Award winning Devon based artist and teacher"
Many thanks, Gilson, UK
Hello !
If you're talking about not having to change anything in years, I hope you're not that far behind when it comes to updating Joomla...
I don't have your template but maybe I can help you. In the Joomla backend you are probably looking for a : J51_LayerSlideshow in the modules. This module WILL then probably be displayed in the position: "Showcase-1".
If you then go to the editing module, look under the "Image(s)" tab, the text should be able to be changed there. Without warranty...
Hi Gibson
Just checking the source of your homepage and it looks like the 'Award winning New Forest based artist and teacher' text is inside a custom module in the 'showcase' module position.
