1. Mallcom
  3. Monday, 27 July 2015
Hi there!
Either I am blind or stupid, but I can not find anywhere how to Florence template only shows "Header images" on the first page, not on any other pages.
Is it possible? And if so, where do I do this setting?
I can not find where!
Regards,
Lars Reimers
Hi Lars
To achieve this you will create a second style of your template specifically for your homepage to which you will add your header images. Your default style will have no images selected and the 'full screen header' option turned off. This will be the style which will appear on all other pages. For details on creating multiple template styles may I suggest the following article.. http://www.joomla51.com/tutorials/item/creating-multiple-template-styles
Thank you, as simple as that!
Works perfectly.
Regards,
Lars
