1. [email protected]
  3. Tuesday, 22 May 2018
Good evening.
I bought your Harmony template for my site http://www.fomet.it.
My problem is in the header: if I reduce the width of the browser, so to simulate a mobile device, I see there is a lot of blank space just below the header, as you can see in the image attached.
How can I remove all that blank space?
Thank you.
Mattia
  1. http://www.fomet.it
This works very well!
Massimo
Does changing the suggested custom CSS to the following resolve the issue?...
#container_header {
height: auto !important;
min-height: auto !important;
padding-bottom: 35%;
Good morning Ciarán.
In the attached screenshots you can see the position of the menu: "Before.png" shows the desired position (it is the current position), "After.png" shows the position after removing the line from css.
Massimo
So you tried the following?...
#container_header {
padding-top: 35%;
Would you have a screenshot of the issue it creates?
Hi Ciarán,
your solution is very good, thank you!
The problem now is it works only for width under 1024px, I think.
Is it possibile to make it work for every width? I tried to remove the line "@media...", but doing so the menu bar goes below the header and I don't want this behavior.
Thank you very much
Mattia
Hi Mattia
#container_header {
padding-top: 35%;
