1. alvin77
  4. Sunday, 09 October 2016
Hy i m trying You free template before buying one for a fee..I want To know why header 1 and header 2 position are not display in mobile version (also in your template classic demo tuo Can See it)..how i Can show those position always?
Hi Alvin
Would you have a URL to an example of your modules?
Yes of corse http://www.madeinporte.altervista.org
If You reduce The browser like a mobile Phone you Will See that The header1 and The header2 aren't display.
I found in The responsive css The instruction and remove It so The header1 and header2 are visibile ma not responsive and overlaps the logo
.header-1, .header-2 {
    display: inline !important;
#container_header .wrapper960 {
    height: 160px;
.header-1 {
    top: 94px;
.header-2 {
    top: 118px;
  3. # 3
Hy Ciaran so it seems to work.Surelly i Will use your Services for my internet site because you have a Very Good and very fast support system.thanks a Lot and if i have other question i Will write
  3. # 4
  3. # 5
I'm sorry another three question.
1- Why modules like SP simple map that display google maps not word and returns a javascript error when i try to display in module position?
I try with different module but the maps don't work (google maps plugin, phoca maps plugin) NOT IMPORTANT
2- Why if i publish a html custom in position top1a and and j_icon module in position top2A i have not a good result in desktop version and not a good responsive result on a tablet?(yuo can see mod-top-good-desktop.jpg and mod-top-good-not-good-on-tablet.jpg) [color=#bb0000]IMPORTANT[/color]
3- Can i set the menu mobile also in orizontal or vertical tablet or change the bootstrap dimension configuration of the devices? [color=#bb0000]IMPORTANT[/color]
  3. # 6
